Clutch pedal sinking! clutch fluid leak?!!?
mattscar
Car: 1989 240sx, 1992 Miata
I recently bought another 240sx ($800!) its a 5 speed with a strong ka24e.
My question is that in traffic when im in first gear waiting, you can feel the clutch pedal sink to the floor, but I remedy this situation by either pumping the clutch a couple of times or kicking it up.
Is this a clutch master cylinder problem?
any help appreciated!
(will post pics in general soon!)
thanks!
nightkid86
Car: 97 S14 SE
sounds like clutch/slave problem or air in the line.
try bleeding it. if that doesn't work try a new slave. if that doesn't work try a new master.
mattscar
should I get an new braided clutch line too if I change it? plus how am I suppoed to adjust the clutch pedal? It squeaks a lot too. I will eventuall post examples.
(sorry for the bad grammar, im just so tired.)
180fan
Car: 89 fastback
yeah might as well change the clutch line and ditch the damper loop.
