clutch pedal shakes when clutching it HELP!
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
after a while of punching my car my clutch pedal will feel like its shakeing when i am clutching it. and sometimes it stays down but not all the way down (about half way). whats up with it? brand new clutch has about 3 to 4000 miles on it and was properly broken in. and everysince new clutch i dont barely punch my car.
EviL inside
Car: 90 240sx
did you replace the throwout bearing also?
240sxvaj
brand new throw out bearing. what else can be wrong?
EviL inside
Car: 90 240sx
new pilot bushing also?
240sxvaj
brand new too. just change about almost 3 weeks now
240sxvaj
bump!
anyone know whats wrong? help!
Jeremy@SPEC
This is pretty indicative of a failing Slave cylinder. The pedal staying low evidences an issue with fluid transfer which is typical of a slave that is on its way. If this is the case the slave will eventually pop pouring fluid out. The down side of a slave that leaks is that is can contaminate the disc leading to clutch issues. I suggest checking/replacing the slave and going from there. Let me know if you have any further questions. Thanks!!!
240sxvaj
slave cylinder has no leak and any other problems. mechanic check it. but there was a weird noise that sounds like a loose cat converter cover everytime i shift gears. i check my cat it felt ok with no loose parts. but then still has the noise.
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
Your flywheel I assume was torqued to spec...
Mine did something like this and the throwout bearing seized on the inputhsaft housing, breaking it off. Not hard to fix, just obviously required pulling the transmission.
240sxvaj
UncleBen wrote:Your flywheel I assume was torqued to spec...
what do you mean by it was torqued to spec? LMK! thanks
240sxvaj
BUMP!
