HxC_Nismo »
https://forums.nicoclub.com/hxc-nismo-u47634.html
Tue Feb 20, 2007 9:43 am
it is year specific, the s13 clutch pedal has no spacers on the mount and the s14 has them built in and the clutch master on the s13 has a shorter rod then the s14 clutch master does. i bought a brand new s14 clutch pedal assy. from the nissan dealer and you just have to piece it together, youll need the bracket, the pedal arm, and spring and it cost around $100 for a brand new one and ive seen people overpay for the same thing but used on ebay. but if you already have the s13 clutch pedal you have to use washers between the firewall and clutch pedal until upper clutch pedal bracket bolt hole lines up with the bolt hole under the dash. and go from there, i just choped my at brake pedal and bought an oem brake pedal pad and put it on there and it looks stock.
