clutch pedal problems
alxjhn
Car: 1995 Nissan 240sx
i have 1992 nissan 240sx with sr20det. The problem i just ran into is that my clutch pedal doesn't come back up. I replaced the clutch master cylinder and the slave cylinder. i still have the same problem. i bled the """" out of the clutch. The clutch is pretty new. The clutch is about 7 months old. I installed the JGY custom light weight flywheel and Stage 3 clutch from JGY custom. I AM STUMPED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Modified by alxjhn at 5:30 PM 2/16/2007
TougeMS13
Car: '91 coupe
Did you leave the clutch dampener in? If so, take it out and bleed again.
Jasong
Check the clutch pedal spring. One leg of the spring could have popped out.
alxjhn
i left the dampner in.I checked the spring everything is cool.
jbennett58
Car: 91 240sx coupe/rb25det
take the dampner out and attach steel line directly to hose
BurnsAuto90
Car: 1990 240sx
1991 240sx
TougeMS13 wrote: Did you leave the clutch dampener in? If so, take it out and bleed again.
+1, take you're time bleeding it...they can sometimes take a few days before all the air works its way out of the system. i've had times when i've bled it out and then the next day, the pedal would be very spongy and i had to bleed it out again.
sochinkyeyesshut
Car: PS13 Sr20Det I/E/FMIC/Tanabe Coilovers and other mods
jack up the passenger front side of the carbleed it slowly.make sure the master cyclinder doesnt go below the middle point .
alxjhn
fixed the problem it was the stupid dampner. I just took it out and the clutch was back.
