Clutch pedal problems...PLEASE READ
drifter92
Car: 1995 Nissan 240sx Small BLock Chevy V8 5.4L
1990 Nissan 240sx Coupe SOHC Auto Wrecked Project Car
I bought a used OEM S14 Clutch pedal, tell me if this is normal or what it is supposed to do.
When i compress the pedal it compresses about 2 inches then slams down all the way, the pedal is not installed, is this normal?? it has a coil spring that pushes it up once it is on the way up and the same spring pulls it down hard on the way down, it's like a toggle switch almost... Is it supposed to be like this??
modulation
Yes.
It's won't "slam all the way down" when it is installed and pushing the piston in the master clutch cylinder.
It also pulls out the piston so that's why it springs back out.
drifter92
thank you very much, i love people on nicoclub...it's like a crystal ball that answers any question about my car that i can think of...
modulation
No problem...
Also take some sand paper/steel wool to that thing and get the rust off and then paint it red or something cool .
drifter92
yea, i am going to sand it and paint it will Rustoleum rust-killer primer flat black and then paint it reflective gold metallic...lol
