clutch pedal problem
kaotiklude25
my clutch pedal on the 240sx sometime gets stuck and i have to manually pull it out to it's original position with my foot ( kinda wack) my friend told meeh it's the clutch release spring that i need to replace...is this true...cuz i can't go into gear sometime...it get stuck like half way up...it's like old hehe and can't get up. thankz
NISTECH
check your slave and master for a leak. sounds more like you have air in your hydrolics.
kaotiklude25
thankz
Scott McLellan
Try the little plastic bushing on the clutch pedal where it pivots. My car had that exact same problem and that bushing was the culprit.
Holisticbeatz
I experienced a similar problem. Read about it here: http://www.nissaninfiniticlub....25352
