krazydriver »
https://forums.nicoclub.com/krazydriver-u56503.html
Mon Jun 02, 2008 5:55 pm
First question is where is the noise coming from?
If it's from down near the pedal, and happens when you release, and sounds like a rubbing popping sound, most likely it's that coiled spring that pushes the clutch pedal back up. Just rub some heavy grease in between the coils and it should be fine.
