Clutch Pedal is weird
coco:v
Car: 96 300zx NA
So im kinda new to all the car stuff, but my clutch pedal was all loose this morning. I pressed it to turn it on but it seemed to have no engagement point. I let go of it and it was stuck all the way in. I heard it could be air inside the system but why tho? I havent replaced the slave nor master. Also it dosent leak at all so im confused. Its a 96 z32 na. Any ideas?
centralcoaster33
Car: 1997 Nissan 240SX #5
Give the system a once over physical inspection to make sure all the bolts, levers, hoses and pipes are connected. Check the fluid level. If nothing obvious jumps out, then bleed the system. You'll either fix it or have problems bleeding that should point you to the source of your issue. Did you find your service manual yet? That has a nice bleeding procedure explained as well as the overall clutch system. Check the CL chapter...
http://www.nicoclub.com/FSM/300zx/1996/
