180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sat Nov 18, 2006 1:29 am
if the pedal don't come back up it could be other stuff as well like maybe the pressure plate is toast, maybe you've a bent fork, maybe you've got plenty of air in the system.
Here's a check list of what to do first. This applies to all of you with clutch issues.
With the car off, have a buddy press on the clutch pedal. YOU look below and see if the clutch slave cylinder even moves. If it does move but you can't shift, you've probably got either a shot pressure plate or a bent fork, possibly the fork popped off the pivot or maybe even the pivot broke. Either way, it's gonna be a pita to deal with. Weep and pull out the box of razor blades now.
If it doesn't move at all, now is as good a time as any to get a new master and slave and dump the damper loop. It doesn't cost much and it'll dump alot of "oh noes, what if..." from your mind. When you pull the damper loop, hold it over your head (of course with the fluid out otherwise you'll look like a total doofus) and run around screaming and throw it into the trash where it belongs. You'll feel infinitely better afterwards. Trust me.
Now another thing to do while you're down at the clutch pedal, put some good lube like vaseline or some lithium grease at the clevis pin (it's the pin that links up the pedal to the clutch master cylinder. It'll reduce the groaning and possible squeaking that comes up every so often.
btw, please no more thread jacks in this thread. that makes me want to end myself. pls.
