Clutch Pedal is sticking again!!!!!!!
TypeX4Sho
Car: 91 Sil40 96 zenki
OK today i was driving and all of the sudden my clutch pedal when i pushed it in it stayed in...i know that this usually means that my clutch master cylinder is bad...but i just replaced it like 2 months ago....this just really sucks because i thought i was done with this problem...oh and yes it is full of fluid....and i dont know if this makes a difference but when the clutch does stick in it has to be pulled hard out of gear into nuteral so it doesnt stall out again...i just didnt know if that might mean something else...now here is my question...the clutch master cylinder that i bought was just a 70 dollar one at Advanced...now i have read on one of the threads when i used the SEARCH button that those are no any good to use..where is the best place to order one ill probably try to get both the master cylinder and slave cylinder...any information would be appreciated thanks..
Blown240sx
Car: 1996 240sx
Sounds like you either broke the pedel assembly or the clutch slave cylinder is busted.
TypeX4Sho
found out what it was...there was a hole in my clutch line haha damn but hopefully that is all that is wrong thanks a lot thoughJ
