float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Fri Mar 25, 2005 5:16 pm
Quote »and its not leaking any fluid when you press it in? I'd say you have a dead master cyl, maybe exchange it from the place you got it at if you still have the receipt, they usually have warranties. I didn't have to do it on my clutch MC, but I know some brake MC's you have to "bench bleed" before they will work correctly... again, grasping at straws... but if you press in the pedal and nothing comes out or leaks, you've got a dead MC. When you loosen the bleeder screw and depress the MC, does fluid even come out? If it does, then it makes me wonder if something inside your transmission isn't amiss, either on the fork or the bearing or maybe the pressure plate itself..[/quote]I get absolutely no fluid movement when whatsoever when I press the clutch pedal down with the bleeder open at the slave. I know that I've got fluid in the MC, lines, and slave, because I've gravity bled the system and am getting plenty of fluid through it with no air. I'm going to try using a vacuum pump tomorrow and see if it helps. If that doesn't work, I'm just going to get another one. The one that I put on there was off of my old 240 and has been dry for a while, but it was in really good shape when I pulled it out and I wasn't having any problems with it before I pulled it out. The only thing that I can think is that because it's been dry for so long (almost 2 yrs) that the seals have dried up and aren't working. We'll see what happens tomorrow. Quote »if i have to replace the slave cylinder, do i get a regular 240 one or should i be trying to get one for a ca motor[/quote]Just use a regular 240sx one. Any local parts store should be able to get you one.
