jam1231 »
https://forums.nicoclub.com/jam1231-u66127.html
Sun Aug 15, 2010 12:27 pm
like i said the clutch pedal goes to the floor i check pior post and change the slave cylinder (sc) and master cylinder (mc) bleed it at the master cyclinder did not help, while i was bleeding it i notice the slave acuator was moving but did not have enough pressure to push in the clutch in. the only thing else i saw in that system was a block with a line going from the mc to a block and on the other side of the block a line going the the sc and another port with something thats looks like a bleed screw (what is this block called) 1992 240sx
