DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Mon Sep 18, 2006 1:41 pm
yep, first clutch jobs are a *****. fortunately, my first was with my dad on one of my beamers when i was 10.
i bought an XTD stage 3, so we're comparable. Okay, pedal height is almost always gonna be different, so you're right to be alarmed. now to fix the engagement height, you lay down by where you foot pedals are, then as you look up check out the clutch pedal.
you'll see that when you push the pedal in it acts on a rod. you'll see that this rod is threaded, and it has at least one nut on it. this is the adjustment. it's hard to explain, but you'll figure it out when you get there. plus if you search around some i know there are pictures on this site.
did you replace the slave cylinder when you did the clutch? because if you never opened up the hydraulic system (whihc i imagine you removed that damper box, which alos attributes to the increased engagement height) but either way.... you have to bleed your *** off.
i got sick of it after an hour with little result and i see that the highest point of the hydraulic system is a metal line running along the top of the firewall. even the resevoir is lower than this point.... so air is GOING to get trapped at this point.
i unbolted the resevoir (the thing thats connected to that rod you adjusted in the first part of this post) and i gently unbent the hardline ever so much. i opened the cap and raised this whole assembly as high as i could. as soon as i raised it to a certain heaight you could see and hear alarge bubble exit out of the resevoir.
BUT.... chances are you are expecting a nice *** stiff clutch right? that would be in the pressure plate. my xtd or exedy plate feels as soft as stock. chances are your pressure plate is stock as well, thats whyfor the difference.
