Clutch pedal braket
That1Guy
Car: 240SX s13 Fastback
I think something broke on the clutch pedal assembly today and my suspicion is that it might be a weld point. Their are no leaks anywhere and the ball nut for the shift fork is a year old. And the pedal feel different. Is this a common problem for the S13 or has anybody had a problem like this?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Not that I am aware of, the pedal is just a mount which pivots and presses the CMC piston. I have never seen one break, maybe the cmc or clutch is on its way out.
That1Guy
I heard something snap or broke Right when i press on the pedal while driving. Any clues?
krash
Check the pin that attaches the clutch to the master cylinder. Theres a bushing and a pin there, if the bushing cracks or breaks of, the symptoms you're getting could happen.
Speckid4
Car: 1995 240sx
1993 240sx
I've seen bent clutch pedal assemblies, but never broken ones. I think it would be pretty impossible. Check the bushing and spring that krash mentioned above.
That1Guy
It turns out that i was correct about the welds on the clutch bracket. It's was like it never had been welded. It shift even better now that i fix it.
super240sx7185
The clutch pedal spot welds breaking is a common problem. Nismo make a reinforced upgrade bracket but im not sure if it will fit lhd cars.
94_240sx
Car: 94_240SX
Check this one. There's not much to break on the bracket. Nismo bracket fits on LHD car.
