DriftBandit »
https://forums.nicoclub.com/driftbandit-u10686.html
Sat Sep 25, 2004 1:58 pm
The little box under the car, the other place you can bleed the clutch from...not the slave cylinder, usually causes problems and is usually bypassed. You can do this by getting a stainless steel braided clutch line, or you can go the cheap way and disconnect the line at the box and carefully bend the line comming from the master cylinder twords the slave cylinder and connect them directly.
And another thing, When you said you bled the clutch line you said you loosened the valve and kept pumping the clutch. If this is true you are doing it all wrong, you need to have the valve closed, pump the clutch and keep it compressed when you open the valve, until you close the valve can you release the clutch pedal.
If none of these work then it might sugguest that your master cylinder is going bad??
Hope this helps a little.
-Jon
