errr wtf. please point out to me where i stated the 240sx is poorly designed vehicle with a weak drivetrain?sanioll wrote:problem here might be, improperly done setup.
I believe you should buy a mustang and change your username. yes 240sx is a very poorly designed vehicle with weak drivetrain. get rid of it.
hope it gets better buddy.
the mechanic said if the clutch overheated it wouldn't work properly, and since 2nd gear is the most work of all gears it would make sense that it wouldn't work for that one.Red-KAT wrote:Well 1st off I dont see how an overheating clutch would keep you from shifing into second gear...
Also if you dont have a full build engine running a stand alone ECU then... yeah 400tq may seem crazy.
Are you sure you have the clutch adjusted correct? If I just push my clutch a little I can get in and out of 1st but not get into second. Maby you need another bleed job.
Just an idea.
I agree. Deleted.Mustangs_Suck wrote:this is probably the most irrelevant and dumbest response i've ever seen to a post on this website.
Thanks - I appreciate itfiznat wrote:I agree. Deleted.
Sanioll, nobody likes a troll-- take that BS elsewhere.
It engages just about perfectly in the middle. It has brand new pilot and throw out bearings/bushings.klattr1 wrote:what part of clutch pedal does the clutch engage? (at top or at bottom). my guess is if its hard to get in gear, then its near the bottom.
so play with pedal adjustment if its not optimized to the middle somewhere (use 12mm open end wrench and look below dash and loosen the nut and twist the rod by hand).
if that doesnt help, then start looking elsewhere.
did you install a new pilot bushing or reuse the old one?
things can happen like a clutch disc installed backwards (believe it or not) or a flywheel come loose (from not torquing down the bolts to 105 ft.lbs with locktite), etc.
so it would really be hard for me to pinpoint just one thing right now without seeing it in person, but i'll try to help you out as much as i can.
after I drive on it for awhile - and kinda be hard on it - yes. 2nd gear just makes this odd spinning/rubbing noise and it's hard to get into. And yes it's only 2nd gear 1st, 3rd, 4th, 5th, and reverse are all find. As for a synchro problem - yes, we're positive nothing's wrong with it.epokh wrote:So, you can't downshift or upshift into 2nd?...and only second?..Seems like an adjustment problem would affect all gears..but still worth a try, especially if this started only after the new clutch installation. You're absolutely certain it's not a synchro problem?
the transmission has only 64k miles on it and was fully inspected before it was put in. had no synchro problems - no nothing. this noise happened on my other transmission (only after the new clutch and all that was put in) and the mechanic said he can't think of anything else that would be doing it, except from inside the transmission - so we got another transmission - everything inspected to be perfect, he flushed it all out, put brand new redline oil in it, and it's still making the noise.Nismo_Freak wrote:Sounds like it is a gearbox issue.
Not much in the clutch can make that noise.
Try rev matching and putting it into 2nd like a synchroless gearbox (double clutch upshift) when it does that.
The only way a clutch will not let you into a gear is if it's engaged, then that is a throwout bearing or hydraulic issue. It doesn't sound like either if you can still engage other gears.
if it's the synchro - why can I get in it perfectly for the most part? As I said this only starts happening after i drive on it for a few hours, and do a few hard shifts. it's like something falls out of place after I drive on it for awhile, and it starts rubbing on something.Ubernoober wrote:I agree, this doesn't sound like a clutch problem at all. This has definitely been isolated to a gearbox issue. I know the mechanic said the synchros look good, but something just isn't right there. Try double-clutching like Nismo_Freak mentioned while it is acting up again. If double-clutching allows you to get into gear, the synchro is shot. Also, with all the mashing that has been done, I wonder whether the shift fork has been bent. Most likely not since 1st and 2nd share the same fork.2nd gear is the first synchro to fail on the 240SX transmission.
Hydraulic problem would produce itself in the pedal feel.Mustangs_Suck wrote:throwout bearing is brand new - as for the hydraulic system - brand new slave and master cylinders - it *might* need to be bled again though...that's the only thing I can think of for that.
true. well i'm very positive it's not inside the transmission. my old transmission did it after the clutch was installed, and this much newer transmission does it as well - i refuse to believe i have just that bad of luck that I would **** up a synchro that fast after installing this newer transmission.Nismo_Freak wrote:Hydraulic problem would produce itself in the pedal feel.
You have a mechanical issue.
that is very possible too. and lol don't worry pretty much everyone is just guessing at this point...you'd have to hear it to understand, and even then ppl are still just going 'wtf'. Hopefully when I get it to Chi-town the problem will be found and eliminated.Ubernoober wrote:Possible bearing failure may cause mis-alignment of the input-output shaft. Beating on it causes it to go wild and won't let you pull into second.Totally guessing here.
