808countryside »
https://forums.nicoclub.com/808countryside-u160904.html
Tue Jul 13, 2010 2:11 am
1985 Nissan King Cab 720 pick-up
5 spd trans
Today as i moved my truck, I put my truck in reversed and moved it just a couple of feet and I still held the clutch in and as i went to reverse a little more the clutch seemed like it was sticking and all of a sudden the truck was hard to put into gear! i had problems putting the truck into first gear or any gear and when i was able to. I tried to put the truck in reverse and the gear would grid.. once i pumped the clutch pedal the clutch would work fine, but as i held the clutch in for awhile the problem would happen again. I've tried changing the clutch fluid and i bleed it properly, still problem occurs. Is the Clutch Master Cylinder Bad or does my Clutch need to be replaced? CAN ANY ONE HELP ME!
