WorkinDriver »
https://forums.nicoclub.com/workindriver-u6593.html
Tue Apr 15, 2003 1:05 pm
It can be ...in my opinion... Mine used to do that...the drain plug was loose and it was loosing gear oil. Check the fluid. If its low or the oil is too thick it will do that... That might explain why it does it less when its warm. When its cold the oil is thick, as it warms it thins. If its not the oil, then its probably the clutch...I might just need an adjustment. It might not be engaging all the way. Try double cluthing when you shif and see if that stops the grinding.
