95lstegman »
https://forums.nicoclub.com/95lstegman-u33967.html
Tue Nov 29, 2005 10:05 am
often when you have a bad synchronizer, the same things that caused the synchro ring to get eaten up causes the shift collar and matching gear teeth to get eaten up. i would pull it apart and check these parts as new ones are so wonderful.
oh, and check your transmission fluid before you do anything. if you don't remember the last time it was done, change it. and if it was a while ago, make sure it's up to the correct level. if you do these things and still have a problem then you can worry about buying another transmission, which is often cheaper than fixing your current one.
however, used transmissions are a gamble, so sometimes one makes the decision to rebuild to new specs and have a nice transmission for years to come.
