Clutch or transmission prob? (searched but can't find answers)
1bad240
Hi guys, new to the nissan community.I just picked up a 92 ka24de. and already having some probs with it. The problem is that when i shift gears, the car kinda revs and then moves slowly. I don't really know how to explain it.
It's like this.
Depress Clutch -> first gear -> let go clutch -> then accelerate. But then the engine revs when i'm accelerating and then the car slowly moves. Same prob for 2nd, 3rd, etc.
Keep in mind that I already changed the Clutch, Throwout bearing, master and slave cylinder. Spent so much money! My mech says that it could be my transmission? The input shaft perhaps?
Please help, thanks in advanced.
pregmantis
sounds likie the clutch is slipping. did you resurface or scuff the flywheel b4 install? was the flyweel glazed/warped? maybe you may need to adjust your clutch pedal/rod. good luck
Red coupe
Car: 92 Nissan 240sx Coupe
yeah man if your feeling slipping there really isnt much room for that other then in the clutch...Every thing else is just kinda gear sets, and gears pretty much either turn or brake, but its not gonna slip.
was the problem still there right after the clutch job? did you follow proper break in on the clutch? Did you change the rear main seal, was there any oil inside the bellhouseing when the clutch was changed, and is it possible the seal is broken and "oiling" your clutches causeing them to slip?
WONTONnPHO
I've been having simular problems with my car. Except that it slips only at high RPMS but the clutch feels fine and everything in the lower RPMS. Is this also most likely a clutch problem?
Red coupe
yeah there is more torque at higher RPMs so its likely just starting to slip...
midwestnissans
Car: 1990 Nissan 240sx Fastback
Sounds like a clutch just get an aftermarket one right away if you plan on modding the car at all i made the mistake of replacing the motor and everything putting on the t3t4 turbo and guess what stock clutch hopefully it will hold up for at least a month
pr240sx
Check the throwout bearing fork, if you installed it incorrectly the TB keeps pressing the pressure plate and preventing full clamping force.
OR
Could be that the slave cylinder is intalled incorrectly and keep some pressure ont he fork
OR
Clutch disk installed incorrectly
OR
Flywheel/cluthc disk contaminated with oil
Either of these symptoms you nned to remove the transmission and inspect.Does it smell like burnt clutch?
240zsx
Car: S13
Hey 1bad240, im have the same problem as what you just describe happen just this week. Have you fix your car yet? I need to pull my transmission out this weekend.
