mechenginic0 »
https://forums.nicoclub.com/mechenginic0-u259291.html
Wed Dec 09, 2015 4:11 pm
Hi all! This is my first post as a member of NICOclub, so TIA for your help, and I look forward to contributing whatever I can. Now on to the issue at hand...
I was driving along the other day about 55 mph and suddenly I could not get the truck ('86 D21, 2.4, rwd, 5-spd) into gear. I pulled over, waited a minute, was able to finally jam it into 1st, but nothing past that and ultimately had to stop and have it towed.
The clutch slave has failed on this truck once before causing similar symptoms, so I was hoping that was the case, but replacing the cylinder and bleeding the system took me back to square one. Of note, depressing the clutch pedal seems to fully extend the slave cylinder's piston, and this time the clutch pedal is HARDER to press in, vs. traveling easily to the floor when the slave last failed. The transmission will shift easily into gear when the truck is off, but it is like hitting a brick wall when the engine is running; no grinding gears, etc.
Some brief searches online suggested possibly bad pressure plate/springs, and the clutch has started slipping every now and then so I know it's on its way out. I was all set to order a clutch and flywheel set online but further digging around on this forum and other places seems to suggest that this may in fact be a synchro problem. I am at a loss as for how to diagnose it and was hoping someone here could shed some light before/while I drop the trans tomorrow. I have done plenty of my own work on other vehicles, but mostly in the realms of brakes, suspension, timing belts etc, so transmissions are still quite a mystery. Thanks again for any help you can offer as to what I should look for, what things SHOULD look like, what it might be, etc.
