It drove fine for about 4-5 days…I felt a bunch more drag that I thought was due to the new mud tires. I also noticed when shifting from no movement to 1st gear, it took much more gas pedal, also from 2nd to 3rd. I just figured it was the meatier tires.
Then I broke down on the way home from work today, 8/1/15, I coasted to park. Thought my clutch went.
I think either my inspection dude had an issue with the rear diff/axles or my clutch took a poop. SYMPTOMS….Truck will not engage into gear. Stick goes in all gears but truck will not move. It will roll back when I try and go. I have been very easy on this clutch and my past frontys. I really don’t think it’s a clutch issue, I think something is not right anymore with the work I had done to the rear diff. It’s 4wd by the way. Can someone please help me to figure this out. I am not a pro on rear diffs or 4wds or clutches. I leave those issues to the pros. I would love to hear that my inspection guy messed up. I don’t wanna fix the clutch and have it go in a week again because my tires are too big or something. I appreciate any help you can give me….Also, If you need more info I am happy to provide it. Thank You In advance Nissan Family….Mark
