iceman1110 »
https://forums.nicoclub.com/iceman1110-u132320.html
Mon Aug 24, 2009 8:12 pm
Ok, here is my problem. I have a 1990 240sx, stock for the most part. I removed the dampener box several months ago. Been going great until this point. My clutch pedal is just sitting on the floor. I tried bleeding the system several times in the past few hours. Removed master cylinder and inspected. There is no pressure in the system, no leaks in the system, you can move the clutch pedal by hand back and fourth all day and nothing happens. With the bleeder loose on the slave the fluid will slowly drip out but does not come out any faster when trying to bleed. I didn't look before at what this looked like, but it appears that the slave cylinder is all the way extended. I can remove the rod from it with the car just sitting there(should I be able to do that?), you can push the clutch fork toward the rod and press it back INTO the slave cylinder about an inch. When I do this fluid comes out of the bleeder screw if it is loose then it returns to what appears to be the extended position. I am completely confused by this and it is my daily driver, no other vehicle. Have to work wednesday so I need to figure this out. Thanks for taking the time to read this, hopefully someone has had this problem and can help.-Mike
