Clutch not working properly
240sx_in_209
Car: 89 240sx.... 93 coupe
hey guys welli got a 93 coupe and i dont know why my clutch is not engaging i replace the slave cylinder and the MC cylinder but now my car is not engaging the only way i can pit it into fist is turn it off and putting in first then turning it on.... the pedal like it feels good then after like 1 or 2 pumps it stays down any help?
Hijacker
Car: '92 240sx Convertible
'94 F-150
Air in the lines. Or more likely in the master cylinder. Rebleed everything.
240sx_in_209
yeah i tried.... i must the bleed it for like 30 min... the cm cylinder and the slave cylinder are new... i bleed and bleed but nothing it still wont work is there any chance it could be a bad pressure plate? if i bleed the line isnt that bleeding the cm cylinder? or do i have to do something different to bleed that cm cylinder?
240sx_in_209
ANY ONE ELS?? help
scottydog
Car: 1992 240sx
Did you bleed the valves at the dampener box and the slave? Check out the manual for instructions on the "unusual" bleed procedure.
Or better yet remove the dampener completely.
erdrift
Car: 1990 240sx
yo whats up man. i had a similar problem with my 90 240sx. it wouldnt engage into third. i would grind and someimes it wouldnt even go in . i took the transmission apart and checked the clutch. my clutch ended up bieng worn out and i ended up replacing the clutch and preassure plate. If the clutch is old (which it might be if you just bought the car) then it might be the whole clutch kit as a whole. Exedy makes a clutch kit for the 240sx ka24e and ka24de. once i replaced it and bled the lines straight it worked fine. no more grinding and all the gears transition smoorthly. but yeah try it out. the cluthc kit costs about $105. Ebay. If you can do the work yourself than you save a big buck. labor at a shope is about 280. cool man. hope everything goes well lates.
Roll out
cleopp3
Car: 93 nissan 240sx
Dampener delete all the way!! just remove that pipe thingy that runs along the side of the car (loop) so that the mc is directly connected to the slave. Way better response with pedal. also did you bench bleed the mc?? possibility of air stuck up there also.
240sx_in_209
thanks alot guys... never thought about that little box
240sx_in_209
hey guys...... well i was going to take the box out but my dad acting like as_s didnt want me to do it because he thinks its going to mess something up.. well i keep bleeding it for like 2 hours and it works fine when i press the clutch fast but if i press it slow it just stays down anyone know why?? plz help me have not been able to come up with anything.... i just have to take the box out when he not here
