Holisticbeatz »
https://forums.nicoclub.com/holisticbeatz-u5589.html
Wed Aug 06, 2003 10:42 am
I know what that's like when a clutch job goes bad, read about it here: http://www.nissaninfiniticlub....25352
As for your problem, it is definately strange that your clutch isn't engaging properly. The thing is, you can't really be exactly certain on what the problem is unless you remove your transmission again. However, from what you're describing sounds like the problem may be in a bad clutch disc. I'm curious, what kind of a clutch you go with?
