Corey B »
https://forums.nicoclub.com/corey-b-u140810.html
Sat Aug 15, 2009 6:27 am
I have checked the pressure plate and the spring looks correct, it has not changed colour at all. I had never had a probelm with it before. The reason I had to change my clutch was because all of the splines were torn out of the center of the clutch disk. The clutch always had lots of feel and lots of clamping force, it will now not disengage(if i start teh car with my foot on the clutch and the car in gear the wheels spin). IS there any way I can check my clutch master cylinder. There is no fliud leaking into the cabin at all.Also, I have moved the clutch fork manually, removed the slave and pushed it with a prybar to see if it was just the slave not moving the clutch fork far enough and it would not relaese that way either as I moved the clutch fork as far as i would go and it still did not release. I have been fighting with this for a week and I have already gotten more helpful answers on this forum so I just want to say thank you.
Corey
