Clutch not going in gear with car running
gawath
I installed a new clutch into my car. I installed the bellhousing by using bolts to tighten it in. Basically forcing the transmission onto the block. (I think this may be the problem). Now when starting the car, I cannot shift into any gear. I can shift into any gear with the engine off. All fluid/slave cylinder/master cylinder is fine. Could this be a pressure plate or clutch problem. Is there any easier way to install the transmission (sliding it in) when doing a clutch job?
mastershake86
Car: 1991 nissan 240 hatch
I got an excedy "oem" replacement clutch kit off of ebay put it in the car and the car would do the same thing so i looked at the 2 pressure plates, disc, ect. and the only thing that matched up was the disc....I did drive the car 200 mi. or so like that it just takes some force lol. i need a transmission so it didn't really matter....and the girl i went drove 200 mi for turned out to be an insane lunatic from CHENDO VALLEY!
koUki20
Car: 89' Nissan 240sx
have you tryed bleeding da clutch?
mastershake86
i bleadthe clutch like he** and was sure it was the pressure plate and throw out bearing......ps don't force youre transmission in just play with the jack moving the transmission until it just slides right in It may seem like a pain in the a** but its theonly way you're gonna make it time to do that girl
