240z4u »
https://forums.nicoclub.com/240z4u-u26156.html
Thu Jan 12, 2006 1:33 pm
Iam going to be taking apart my S14 sometime in the near future but was wondering if anyone else had simalier issues.
Basically the clutch engages at the very end of the pedal travel. I have tried adjusting the master cylinder. I have also put in a new rb25 slave cylinder and s14 clutch master. I also checked my hardline for crimps or tight bends that would impede fluid flow.
I am still having the same issues, clutch engages pretty normally from stoplights, but at any boost above 7psi the clutch holds then all the sudden lets go. It does not start slipping, but all of the sudden lets the motor rev high with no accelleration.
For some reason I noticed this really bad after driving many hours on the highway to indianapolis. I did NOT ride the clutch at all, it seemed like pressure built up as I was driving. The pedal got very stiff, and it got more normal if I held the peddle down or pumped it a bit.
It does not seem to matter whether or not the car is cold, but it slips less when the car is cold. Logical since the clutch has not heated up yet either. I used the XTD 300zx clutch, bolted up like a charm with no issues. I also used a 300zx throwout bearing. Everything bolted up normally and I did NOT have to pull the halfs together with the bolts.
Any thoughts/suggestions would be great!!
Thanks - Evan
