BarnDog296 »
https://forums.nicoclub.com/barndog296-u29477.html
Sun Sep 03, 2006 5:40 pm
alright, recently I just had my car converted from auto to manual
after driving it around for a bit, it seems that i am having some weird problems. I really dont have any major knowledge about transmissions, but I need to know what is going on so i can tell the ppl who are going to fix it.
Problems:The car will sometimes NOT go into gear easily at all. I will sit in neutral and it refuses to go into first or second or ANY gear.
When I finally FORCE it into gear it has like a spinning grinding sound going on. It sounds like the the gears in the transmission are engaged, but they are still grinding, but not extremely loud, but enough that it cant be normal.
Now this doesnt happen all the time, but enough that its a real problem. Sometimes I push in the clutch and it will go into every gear just fine, but then other times it just does NOT want to engage at all.Its about 50% of the time for each
The other thing (if this helps) if I am riding the car fast and changing gears in higher RPMS, like over 5K or so (like it was doing just fine when it wasw an automatic) then it will NOT let me go into 3rd gear w/out forcing it hard
This CANT be normal
