clutch not disengaging
gray240321
Car: 1991 240sx sr20det
i recently bought a blacktop sr and transmission 4 my s13,we pulled of the tran. before starting the swap and found a twin plate OS GIKEN.changed tran. fluid before puting back together, now the slave cylinder isnt pushing the fork out enough to disengage.bought new master clutch cylinder and slave but problem continues
justy90240sx
Car: 90 240sx se, 95 240sx, 92 300zx
have you adjusted your pedal or bleed the master cylinder
gray240321
yea,pedal is screwed all the way out and i blead the slave 30 times,i might try to fab.up a longer slave pin, any sugestions help
numnutzzz
do u see the slave fully extend while your friend is stepping on the clutch?
gray240321
no,thats the problem,it comes out but not far enough,if i move the fork far enough with a pry bar i can spin the dr.shaft with my hands,but tryin to start car in 1st with clutch pedal to the floor..car jumps foward
scottydog
Car: 1992 240sx
Readjust the clutch pedal free play, as it sounds like it's too loose.
Also dump the crap dampener box down by the slave cylinder if you still have it. If you want to keep that pos box make sure you do the proper bleed procedure as there are 2 bleed nipples down there.
Modified by scottydog at 9:31 AM 2/21/2008
finallya240
Car: 1993 Nissan 240sx coupe
how much were you able to pick up the sr for? How long did it take you to install?
numnutzzz
did u bench bleed the clutch master? there might be some air bubble in there that's keeping the slave from extending all the way.
gray240321
apollas
Car: rb20 type-m
If you have installed the clutch correctly and bleed it correctly then your prob is clutch block.
heres how to fix: http://www.nicoclub.com/articles.php?id=251959
I had the same prob when I swapped the rb20det into my car.
numnutzzz
apollas is talking about the dampening box. if you got a steel braided line from your master to slave you'll eliminate that box and get a better feel on ur clutch. and what i mean by bench bleeding your clutch master is before u install the master, you bleed the master alone, then the clutch system. i put mines on a vice and bench bleed it before i installed mine.
gray240321
I took the slave Cylinder rod out, then took a rod the same size and cut it a little bit longer and now it works ?
numnutzzz
how do you cut it alittle bit longer? wouldn't cutting be shortening the rod already?
