Clutch MC not working?
b00stinbmx
Car: 1990 240sx hatch rb25det. drift slut
hey guys im finishing up my rb20det swap into my s13 and im stuck on the clutch now. i bought the car as a shell and it previously had a rb20 in it so im pretty sure everything was working but right now as it stands there is fluid in the reservoir and no hard line hooked up at all, i need to make one up. but as it is the clutch pedal stays to the floor and when i go to grab it and pump it up no fluid comes out. if i hook a fitting up to it same thing, so i need to first figure out why the pedal is not pushing any fluid through before i go any further. yes the pedal is connected to the rod going through. any ideas?
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
bad mc or just an a$$ load of air. make the line then bleed it. or, hook a a clear plastic tube and run it from the fitting to back into the resevior and pump. thats how you bleed it
