CLUTCH master cylinder upgrades???
needs_a_240
Car: I need a 240 BADLY!
Are there any possible upgrades for the clutch master cylinder on an s14? I am putting in full S.S. clutch line, Nismo slave and pivot, fidanza flywheel and spec stage 3+ clutch. Just want to know if I should get a new OEM master or if the is something out here I just haven’t found yet.
SR20Essex
Car: 1989 Nissan 240SX, 2007 Infiniti G35 Coupe
Not that I know of. If your trying to make the clutch easier, I don't think tha would work. I thought the same thing, but after I did the SS clutch line, clutch MC, and "special" clutch fluid, I noticed absolutely no difference. I still have to do the 300lb leg press to get my darn puck racing clutch to seperate from the flywheel. Besides going with a softer clutch (that will most likely slip under the HP my car is putting out), if you find another solution, let me know.
180fan
Car: 89 fastback
nope, go with the oem master. the nismo slave will make the pedal a bit softer and more managable if you're using a heavy duty pressure plate on a single disc clutch setup.
