clutch master cylinder removal
aurora61
Car: 1990 240sx hatch
Is it possible to remove the clutch master cylinder WITHOUT having to remove the brake booster? I can remove one of the 12mm nuts, but the other one seems impossible to remove with the brake booster in place. Any suggestions?
Hijacker
Car: '92 240sx Convertible
'94 F-150
extension and ratchet. It's obsurdly easy to get the clutch MC off.
aurora61
Hijacker wrote:extension and ratchet. It's obsurdly easy to get the clutch MC off.
Yea i know its really easy but i still cant reach that one nut
Are u using a 1/4" ratchet? I dont own one so ive tried several extensions with my 3/8" ratchet and it just wont fit in the gap
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
get the right tool for the job. its very easy. the booster just sits a little close to it. use a 1/4 with a wobbly extension, or just use an open ended wrench if you have to.
