Logan76 »
https://forums.nicoclub.com/logan76-u38992.html
Sat Jan 20, 2007 10:50 am
okay Ill explain it a bit better, by bench bleeding it, you will save yourself alot of hassle in the bleeding process, take your master cyl. and put it in a vice, fill it up with your brake fluid, and push the metal arm that attaches to the linkage on your clutch pedal, keep filling it and dont let it run dry, until the master cyl. itself is bled, then take it over to your car and install it, hope that helps.
