the_invisible »
https://forums.nicoclub.com/the-invisible-u5272.html
Thu May 22, 2003 5:21 pm
So this grinding noise should be your last problem huh, supposedly?
Well, it sounds like that there is a loose spring in your transmission and maybe your throw out bearing needs replacement. That SHOULD help reduce the grinding noise, if not eliminate it. Grinding noise like this also indicates a bad transmission. If it doesn't shift too bad and isn't grinding, you shouldn't have to worry about it too much.
Also, after you drive your car, do you smell something like the clutch burning? If there is air in the hydraulic system, chance is that your clutch isn't disengaged fully and causes the clutch to rub the flywheel, making the grinding noise. But that is very unlikely.
Have you replaced your clutch?
I remeber you had a dented oil pan and your valvetrain was running dry and you ended up damaging your engine. How did that go? Got that fixed yet? What happened?
So you have also flooded your engine and fixed it by reconnecting your SMIC, how did that go as well? Did you fix it?
