Clutch Limits
Edub1
Car: 89 240sx KA-T
I found posts on clutch problems but none on clutch limits.
What HP/ torque can a good, low mile stock clutch handle?
What HP/ torque do the popular aftermarket clutches handle?
Looking for experience, not manufacturers claims.
wild_maxx
Car: 90 TT pearl yellow z32
when you buy a clutch you make sure the manufact. specs are higher than what you plan on making in ft. lbs of torque. It's not a rule you have to follow but it's a good idea to give yourself more room to work with in the future.
BTW. ACT clutches are rated low in terms of holding torque. They are great clutches and hold more than they claim.
Florida240sx
I got an rps clutch. Stock clutch will only handle about 200. After that you are lookign for it to give out
Chezedik
Car: 1991 Nissan 240sx
200 ft/lbs?
nismofly
Car: 89 Nissan 240SX Hatch
lb-ft...
also probably right around there, most people with mild builds run act street or whatever its called, i think that holds like 270 lb-ft
i plan on getting an rps next summer, the heavy street one holds 400 lb-ft, should be plenty for me
MarkEmark
Car: fully-built '95 240sx KA-T
My stock clutch started slipping in every gear at around 9 psi from a T3 super 60...
But when outside of boost, the clutch worked perfectly--still released from right off the floor and engaged fine...
I have an ACT street clutch right now and couldn't be happier with it...it's only rated for like 275 lb-foot of torque, but apparently people have made up to 420rwtq with it, no problem. Good clutch that combines easy driveability with performance...
wild_maxx
i have the extreme PP with the street disk. It's pretty firm but i don't mind.
Turbo 510
I just replaced my Centerforce "Duel Friction" clutch with an ACT Extreme PP and a street disk. I'm told that is a great set up but haven't had it on the street yet. The Centerforce is a piece of crap. It started slipping the first time I had it out and only got worse. I finally had to pitch it.
hek1620
Car: '89 240sx
i have a centerforce DUAL friction and the **** never slips and it's not too firm. been driving on it for about 30k miles and no sign of problems.
KATwo40
Car: 1993 240sx KA-T
It's ft-lbs, not lb-ft. (when talking about engine torque)
The other way around (lb-ft) is talking about things like torque wrenching a bolt.
Chezedik
So suck it!
thekawaii
Car: box with 4 wheels
Brand new stock clutch can't handle 3 psi.BTW. I'm looking for new clutch too.
Anybody heard of F1 stage 3 clutch on ebay? any feedback?
KATwo40
thekawaii wrote:Brand new stock clutch can't handle 3 psi.BTW. I'm looking for new clutch too.
My stock clutch held 215ish whp. (10psi on a small turbo). However, if I dumped it hard, it would slip. It would NOT slip when I was @ 190whp.
I'm about to do a writeup on the Ebay XTD Stg 3 clutch kit.
thekawaii
mine (small T3) does slip at 3 psi. We even tested it multiple times. It sucks.
(I heard XDT clutchs are horrible. some says he did 12k out of it, some say did only 3k out of that stage 3 clutch)
98240
i have a act heavy duty pp organic street disc and my pedal is pretty soft softer then stock
Edub1
Car: 89 240sx KA-T
How many miles are on it? Have you tried adjusting it?
thekawaii
about 3-4k on the clutch. I installed it before i got turbo, it was fine. Just can't handle TQ.
