Clutch kicking
Nissan dominates the drift scene - Always has, always will.
Dori Dori
Car: Cars of course
I did a local drift event this past weekend and clutch kicked 800x more than I usually do. I used to practice braking drift as my main initiator, but this track was too slow for that. Anyhoo, just wanted to let everyone know that I improved more than I ever have before...by the end of the day, I was hitting almost every turn exactly how I wanted to. I'm definitley going to use this technique more often.
On a side note, I had a huge brain fart...I got 'confused' in the middle of one run and I clutch kicked and pulled the e-brake at the same time. I had to slap myself in the back of the head for that one. I felt like this guy-->
Silvia007
Car: 93 Nissan 240SX SE Fastback
HAHAHA, man, sounded like you had a kick @ss time. That's all that matters.
Saru of the West
Car: 91 240sx & 1997 Q45
we are all just victims of causality.
IlIkEmYz
Car: 06 Z
as my friend say if you are understeering just kick the clutch like a B!@#*.
silkk
Car: 94 B13
89 S13
07 S2000
Or pull the e-brake.. if it works.
BuudWeizErr
clutch kicking: the solution to undahhhhhhhhh
ca-jon23
Car: '96 White Zenki, S13 Blacktop
Yeah, my car understeers like a mofo, I didn't wanna try clutch kicking cause I was afraid the rpm's would go to high and my engine's about had it as it is ! But maybe I'll try, blow the engine, and get a ca
azncorruptedo17
Car: 1991 Nissan 240sx SE
clutch kicking is fun
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
I think clutch kicking is the easiest way to initiate the drift unless the track doesn't allow it, as in its not slow enough to clutch kick it out.
Axel Grungy
Car: 2001 G20 5spd
wont this burn out your clutch really quick tho?? i would think this would be horrible on your clutch...
574-240sx
Car: Nissans, Toyotas, Subaru
Get a good clutch. Its not that bad on the engine if you maintain it. I personally like to use the ebrake because my car understeers horrible too.
eliterit
Car: pignose
the only time i've been drifting is in the rain and all that day i used clutch kick
my e-brake wasnt quite functioning at all. even in the wet
Florida240sx
The only time my ebrake works is in the rain. Or if I'm completely stopped then it will hold. Only time I use e-brake is empty lot and I just pull it just to spin in circles.
Return to “Nissan Drift Forum”
