Clutch keep loosing Pressure, please help.
JdrifterCA
Car: 1992 240sx LE
Hello fellow nico members, my name is Jason and my 1992 240sx have a really bad clutch problem. I bled the cltuch atleast 6 times now, everytime after I bled the system, it will be fine for a day or two, then it will start too loose pressure.... the pedal will be so soft, and will not return to position, and of course, no effects on the clutch when i press the pedal. But after pumping a few times, it will work a few mins, then it will turn into few seconds, and then i will have to pump it 10 20 times to just get enough to disengage. Please help. PLEASE.... i had my 240 for a year now and Not a full month that i got to enjoy the car w/o having to fix somthing. Thank you for reading, and appericate for all help. If you live close to phelan, and you have some free time i will grealy apperciated if you can come over and take a look at it for me. I did bleed the clutch correctly, and both cylinders are new,(stil could leak right?), and i use dot 3 brake fluids from auto zone. My reserivor never did loose fluid level, but if i open it when the car is hot, it will spill over a lil, and the lines are really hot.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Sounds like a bad slave or master cylinder. I would replace them and you should be all set.
sean@z1
Car: 1993 240sx
Check you slave and master cyl
Justin35ll
Car: s13 coupe sr20det
maybe you should check the slave and master?
