DJ8684 »
https://forums.nicoclub.com/dj8684-u21591.html
Fri Dec 17, 2004 10:00 am
my clutch starts slippin and my clutch pedal changes feels before it does it. I changed the stock clutch and pressure plate on my S13 SR20DET with an Exedy kit, i replaced the throwout bearing, & sanded the flywheel and replaced the slave cylinder. On a cold day, the car would drive fine. Still slip a tad but hardly as much but when i drive when its now like 80 degrees, i feel alot of resistance from the clutch. I had these problems before i changed my clutch and all that stuff before and thought the clutch would solve the problem but it didnt. So i drive around and its all good except if i push the car a bit in a gear too high it starts slippin, and the feel of the clutch varies, but by outside temperate which is strange to me, if its hot outside, the clutch clamps almost right before the pedal is almost fully released, if its cold outside it clamps before mid point. What can it be??? Im afraid to spend all this money replacing the clutch and flywheel with brand new OEM parts and have it still not be the problem. i know others have had this problem but no one has yet to really give a cause and solution to this problem. Please help
