Clutch Issues??
ILOVESILVIA(S13)
Car: 93 Ca18det Hatch, 03 Subaru WRX Wagon (daily), Subaru Legacy Limited GT (daily)
I seem to be having some clutch issues with my car. Some background first. I had the clutch/slave cylinder/master cylinder all replaced about 2500 miles ago. I have never had an issue with my clutch/transmission or anything related ever before. Well, this morning I woke up and got in my car to go to the gym and noticed that my clutch pedal was sort of stuck mid way in its range of motion. Popped it up with my foot, depressed the pedal and started the car. As I begin my drive I notice that it takes a lot of force to get it to go into 1st gear as well as reverse. Also, it seems as though my clutch does not want to really engage until the pedal is almost hitting the floor. Like it needs more distance to go before going to full engage with the pedal. But of course I cannot because it hits the floor. I checked to see if maybe I was leaking any fluid from the master cylinder as well as the slave cylinder and did not notice an visible evidence. In any case, does anyone know what may be going on? It was kind of cold this morning if that has anything to do with it? Does the pedal need to be adjusted? Anyway, if someone could possibly point me in the right direction it would be great. :bigthumb:
**(I also posted this in the 240 Tech Forum but there is less traffic there so I am posting it here)**
midnightouge
Car: 91 Fastback
You obviously didn't bleed the slave cylinder right.
Do that again and get rid of the damper.
EnjoiNismo
Car: 93 240sx
For some reason, if its cold or hot out, some clutch pedals will act weird. The engagement part of the clutch changes.
Adjust the clutch and I would recommend rebleeding
ILOVESILVIA(S13)
A transmission shop did the replacement by the way, so I did not do anything wrong. I'll see what I can do. Thanks for the advice.
ILOVESILVIA(S13)
Just went out to check on the car in my free time. Noticed a small puddle of fluid coming from the dust boot of the slave cylinder. I think this may be what is causing the problem. Anyone have a 2nd opinion?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Try rebleeing it, and clutch rod adjustment.
