CLUTCH ISSUES
oddball80
Car: '93 240SX SE
My wife didn't drive my 240SX while I was in Iraq and now I'm having a hell of a time getting my clutch up. I got in to drive it and had no resistance to the clutch at all, my pedal was a free for all. Replaced the master and slave cyls, put in a Sachs clutch and Fidanza 11lb flywheel. Still nothing. My damper and slave are both pushing fluids but the clutch just will not engage.
navysnail
did you bleed the system well? it sounds like you have air in the hydraulic system. have someone watch the slave cylinder while you push in the clutch, it should push the fork on the transmission. if it does not, its a hydraulic problem.
