sandersb »
https://forums.nicoclub.com/sandersb-u78770.html
Sat Aug 09, 2008 7:18 am
To start, I have a 1992 240sx w/ a redtop SR20DET.
I got everything mostly finished with my swap, with only the transmission remaining; all I had to do was fill the clutch master cylinder and bleed the clutch system. I had already filled the transmission with 2.4L royal purple synthetic gear oil, and bypassed that PITA pressure relief box on the subframe.
After filling my master cylinder, I spent about 1 hour bleeding the clutch, with a friend in the car pumping the pedal; I even let it gravity bleed for a bit. Now I have pressure in the pedal, but when I start the car and try to put it in gear, it grinds as if I'm not pressing the clutch in at all, or very little at least. I checked under the car, and when the pedal is pumped, the slave's pin does move quite a bit.
Is there anything I could check, or anything I possibly overlooked?Or could it simply be a matter of air still in the system (hopefully)
Any help would be greatly apprecated
