MagikDragon »
https://forums.nicoclub.com/magikdragon-u24311.html
Thu Aug 10, 2006 7:32 am
if you read the post i bled the system many times using 3 different techniques, old fasshioned pump pedal, open close valve release pedal, using a speedbleeder instead of the stock bleeder, and using a vacuum pump to presurize the system. and remove the air. all three no change in pressure for bettor or worse. there seems to be some play between the pedal and MC and i dont like that i like a nice solid pedal, not nessicerily hard but I like positive engagement. I've ruled out all of the things you have mentioned, I'm looking for other suggestions, i.e leaking coolant on the flywheel, or something like that.
