Street1 »
https://forums.nicoclub.com/street1-u131110.html
Wed Apr 08, 2009 4:57 pm
ok this is one challange for me...I own a 96' Nissan Maxima 5-speed 3.1 6 cylinder...one night my clutch let loose..i had no pressure after work...filled it with brake fluid drove fine...woke up one morning had the same issue..fluid was fine...figured it was the clutch master cylinder so i replaced it......only recieved an inch of pressure, not enough to get it into gear..oh it's also a hydrolic clutch...so i then proceeded to replace the slave cylinder...bled it out...nothing....so i had someone get in the car and pump it up while i held the forks off the slave with a pry bar...when i let the pry bar go i seemed to hear (and feel on the master clutch cylinder) like air had flown out of the master...yet the master was dry everytime i went to work on it...no fluid leaking and when i felt the air there was no fluid spewing out...i am stumped..my father has been a diesel machanic for 20 something years and can't even figure it out...if someone could help me i would greatly appreciate it..
