I posted previously asking about replacement clutches, thinking that my current clutch is currently dying on me... but after a little test-driving tonight I'm starting to think otherwise.
Heres the deal:
I took the car out tonight, after tightening up my E-Brake cable (I tightened it up a good bit, but it still feels weak/sloppy, but thats a different story). And I noticed that my clutch WASNT slipping for once.
Intrigued by this, I went out on some back roads, and did a few light starts, no slip, I did some testing with it, starting at 2000 rpm in 2nd gear, stomped the gas, NO slip.
Normally the RPM needle would surge up a bit, meanwhile my speed would stay the same... but this time it was different.
So, further intrigued, I shift to 3rd gear, the gear that has been notorious for slipping (cuz thats where i spend most of my daily driving time).
2000rpm, stomp the pedal, pure acceleration, no slip.
HAPPY DAY! i think.
so i keep testing, no slip, no slip, no slip, no slip..... SWEET!
then i try a hard-shift.... 2nd to 3rd.
upon dumping the clutch, the rpms stay up at 4500, instead of dropping to like 2500(i think) or so like they should.
the cars speed kind of plataeus, and the rpms slooooooowly drop down, till i give it a little more gas.... upon which the RPMS raise, but the speed barely responds.
"DAMN" i think.
I continued various testing like this... and found that after a while, the clutch would slip even at the 2000rpm starting point with a good stomp on the gas.
Now, i havent paid too much attention to the conditions for slippage in the past, but i have noticed a very inconsistent, largely fluctuating amount of slippage. some days it holds like a champ, some days its a miricle if i can keep it from slipping with the most granny like driving i can possibly muster (trust me, i can drive like the slowest of them if need be :P)
My question is this:
If the clutch itself needed replacing due to wear, wouldnt the slipping be more of a consistent problem? These inconsistencies... could they be caused by the hydraulics?
I know for a fact that the seals are going, because the fluid in the master cylinder reservoir is turning black, and ive had to top the reservoir off once or twice in the last few months. Could leaky cylinders be cause to fluctuating clutch slippage? (i.e. not fully disengagin? air trapped in changing compressibility with temperature? anything?)
Thanks in advance for any responses
p.s. pardon any typos n stuff, its 4am over here and ive had an erratic sleep schedual for the last few weeks :P
