Thoughtful_One »
https://forums.nicoclub.com/thoughtful-one-u29843.html
Mon Dec 18, 2006 2:59 pm
The other day, I noticed that the clutch was starting to grab at the very bottom of the pedal movement. I checked the res. and found that the fluid was very low, so I filled it up and then adjusted the small bolt connecting the pedal and MC by rotating the bolt. I then took it for a spin and found that it engaged even lower, but the play was removed from the pedal. There is only about .5 cm left of thread for me to loosen the bolt as well. The fluid was very dark when I checked it before I added the new fluid. Also, I had a mechanic change the slave a few months ago and he had to have filled it. When I did an oil change the other day, I didn't find any leaks anywhere. It seems that someone removed the clutch damper before me, meaning that it can't be a source for fluid to leak from.
Do you have any suggestions?
