Is your Z an 07' if so its the slave cylinder. the throw out bearing and slave are intergrated in one unit and made of cheap plastic. At my dealer we have replaced many with the same symptoms you stated.Blueknight74 wrote:--------------------------------------------------------------------------------
Help me please. I was parking my 04 Z & when I stepped on the clutch it just went down & would not come back up. I check the clutch fluid its fine. what should I do?
evildky wrote:if you plan on modifying the car and voiding the warranty go ahead with the upgrade, if you plan to keep the car relatively stock or value your warranty, stick with the stock replacement
