JaredBorden »
https://forums.nicoclub.com/jaredborden-u58485.html
Tue Jun 19, 2007 6:09 am
I think something is wrong with a component in the hydraulic system of my clutch. It just feels super buki. There is hardly any resistance when I depress the clutch, and it doesn't really kick back like there is any pressure behind it (it kicks back like its spring loaded rather than hydraulic if that makes any sense). The clutch does engage and disengage properly it just has a buki pedal and every now and again it feels like it has two friction points or two different levels of the clutch being engaged. This soggy set up makes clutch kicking into or during a drift difficult. The entire system has been bled (at the box and at the slave) and the car has been converted from SOHC w/auto transmission to DOHC w/manual transmission. I don't know if I overlooked something or what. Someone told me that bypassing the bleeder box would help. I read that the only thing that the box does is reduce chatter during gear changes by opening and closing a valve (which in turn modifies the clutch pressure) creating a sort of cushion so that the driver doesn't feel it in the pedal. Any advice would be greatly appreciated. Thanks!
