clutch is slipping
ZeroCoolll
Car: 1989 Nissan 240sx
i think its the clutch when i rev the car up to 2000 to 3000 and let it go it does not spin the tires it just moves the car and almost free revs like the clutch is slipping. it just started doing it like 2 days ago still drives great other then that.
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
when was the clutch last replaced and how many miles are on the motor?
check and make sure no oil is leaking between the bell housing and the rear of the motor. otherwise you have a bad clutch or a leaking rear main seal.
ZeroCoolll
i am almost sure it has no leaks no idea when clutch was changed last the guy i got it from didnt know much about it he had recently got it from some one else its got 288,XXX KMs
jdm_master_X
it slips regardless of conditions? normally if its a rear main seal it normally takes awhile for it to slip during driving (in my case it was driving for more than 30-40 minutes. )
ZeroCoolll
its always slipping from the time i start it tell i stop it.
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
replace the clutch?
