SrSLeePeR »
https://forums.nicoclub.com/srsleeper-u316.html
Fri Sep 06, 2002 4:56 pm
Well..when I first started up the SR20, it was fine...the clutch was good and there fluid was full....after a week, I came home and saw a puddle from underneath the car....I thought it was some more transmission oil since I was leaking that but it was a big wet puddle...I look at it and touch it and i figure out its brake fluid....It was coming right under the clutch bleeder. I went inside the car and the clutch was all the way down....no presure at all...so i'm guessing the bleeder wasnt tightened that good. Me and my friend bled (spelling?) the clutch and everything seemed fine....Clutch was harder than normal so that was good for me. 2 days later, its getting soft again and notice a puddle at the SAME spot..now I know its not the bleeder....but Im confused to see where it would be coming from...
Do any of you guys know what might of happened? what could be the problem.
BTW, I dont know if it makes a differnce or not, but the clutch is an ACT 6puck...
-ThankS...
-Albert
